Inverter Duty Motors
The Plc Kid
Feb 2009
Macon, Georgia
3,233
Cost not being an issue what are the best vfd duty motors out there. We currently have some of everthing but i have not been here long enough to see a failure pattern between brands.
Any opinions of favorites?
Kid
I think any of the large well know builders will result in about the same performance. I think Leeson Baldor etc etc.
Maybe more important
1. Availability
2. Local supply
3. Local support
4. If they are going to be able to do (and really do it) 3 above for next 20 years?
If I had to pick one outfit to do motor support / replacement anywhere in USA it would be Grainger - I have had good luck with them replacing some oddball motors and getting it right. Course that is limited to what they normally do - up to 100 HP.
Dan Bentler
In my view, Reliance/Baldor's RPM-AC and ABB's HDR motors are as good as can be found.
In fact, for many jobs they are too good.
So, as always, it does no good to overspecify but it's worse to underspecify. Knowing and understanding your real needs is essential.
Shucks, a TEFC Class F MG1P31 motor just might be good enough!
Good Morning , I am working on a new project and I am using 3 Inverter Duty motors. 2 - 5 HP motors and 1 - 3 HP motor. I am using PowerFlex...
3,433
Good Evening , I am using Inverter Duty Washdown Motors for the first time for a small project. How different are they ? It is a 5 hp and...
3,438
Motor: 60HP (44.8Kw), 480V, 60Hz, 1200RPM Application: Axial piston hydraulic Pump, w/ electronic volume and pressure comp controls. Motor will...
4,377
Good Morning , I have an application that I would like to put a regular fan cooled motor on a drive instead of purchasing a inverter duty...
2,994
Hi folk, I would like to know what kind of Parameters should I setup for controlling with Profibus. My old Lenze 8200 motec 0.25kW have a busted...
82
