IP adressing VS Serial
Jeff23spl
Jan 2010
Canada
860
Hello
I'm wondering if some of you have figured out a solution over ethernet connection for small application with multiple local panel using the same program....
Previously with serial communication we just had to connect the cable between plc and hmi and all setup could run on the same node adress...(PLC = node 0 HMI = node 1)
This way, even if you have 10 unit on the same plant, you could use 1 spare plc that could replace any of them and the same for hmi...
But now with Ethernet device, everything is connected thru 1 ethernet network so the same 10 plc with 10 hmi need an unique adress for each.
If we have to replace 1 unit, we need to program is ip adress to fit the broken one...Or if we sell a new unit, we need to ask for a free ip adress...
Is there any easy option to made this easier...
With some HMI's, it is possible to automate the process of assigning the IP address, making it part of the boot up process for your spare. I have a G3 that can do that. I did give it an "out of the box" address that is reserved for it as a spare, in case we want to do a download over ethernet, should something go wrong with the clone card at the machine.
The technician is prompted to select (from a list of buttons) the machine name when it is powered up (or programmed) for the 1st time under normal conditions.
I am trying to connect to a Chiller through Modbus TCP that has been setup as a Modbus slave and I see the Rockwell AOI and it looks pretty...
388
Hello Mates, first time developing with deviceNet, Im more used with S7 CPUs. My system is a L23E CPU + PanelView 550 on devicenet. I can't...
776
Hi everybody. I got some problems about how to perform this task Now, I got an FB where I have this code snippet that looks like: L P##DBD_134...
1,143
Hello I got a request to make an exchange table using numeric addressing for a controllogix plc to talk with customer DCS (Delta V) I usually made...
2,390
Gents, I've not had much dealings with indirect addressing, but I'm troubleshooting a program now, and I just wanted to verify that I've come to...
3,007
