IP network addressable relay/contactor
danw
Oct 2004
midwest, USA
3,428
Is there such a thing as a commercially available relay/contactor that is also network addressable (ethernet IP) with a network function that can override the conventional coil signal?
Load is 5 amps @ 120Vac.
Dan
Hello, I have a A.B Compact logix communicating with two fanuc robots via ethernet. The plc also communicates to an automation direct hmi screen...
440
So I'm pretty new around here but I come looking for advice or suggestions to research. Im the plant electrician/SCADA guy for a warer department...
286
Looking for a supplier of Layer 3 Network Switches DIN RAIL MOUNT, in Alabama, In the UK we would use Typically in the UK we would use...
220
We are having an issue with some servers, with "Teamed NICs" is we plug one cable leg of the team into one switch and the other to another...
72
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
953
