OkiePC
Yes. In the PLC I/O advanced configuration and/or ladder logic you will want to convert that voltage signal into engineering units.
Most likely, when you order the sensor, you will, in addition to 10vdc output, choose the output range you want to correspond with the voltage signal. Match that up with the application requirements as best as possible With 12 bits of resolution, you should be good to go in the Micro, and be sure to let us know how the sensor performs.
Omega may have a config wizard to help you build or narrow the list of part numbers...many of their lines have nice helpful config. tools.
