Is a major fault stored in the CPU after someone goes from RUN->PROG->RUN to reset
I recently had a CPU go into fault and a worker turned the key to PROG and then back to RUN, is the major fault still stored in the CPU's memory so that I can connect a laptop with RSLogix to it and retrieve the code, or has it been erased?
