Hi Gents, this is a tricky one. I am waiting to receive an actual Modicon M340 PLC, but I would like to test my code. Is it possible to connect Citect 7.20 to the Simulator that is built into the Unity Pro software?
I have been able to connect Vijeo Citect to the simulator through OFS, and expect that the Modnet driver would work just as well in VJC.
The key is selecting which IP address to use - when you open the emulator it will tell you what address to use (you should be able to use localhost as well - 127.0.0.1):
