IS IT POSSIBLE TO CONNECT SIEMENS CPU313-2DP TO (SIMENSHMI & DRIVES) AT SAME TIME
sundar_scada
Jan 2008
kumbakonam
25
Hi i am new one in simens hmi & drives. I am using CPU313-2DP . I have to connect simens HMI(MP277) & SIMENS DRIVES at same time. how should i connect anyone help me...
soony11 is correct.
However, it is also possible to connect both profibus slaves and one or more HMI panels to the same Profibus port.
Advantages with connecting the HMI to the Profibus port:
The HMI can update faster if the Profibus runs at 1.5M or 12M.
Longer distances than 50 m. can be reached.
Disadvantages with connecting the HMI to the Profibus port:
The update of the slaves will be much slower. The socalled Token Rotation time will be increased by appoximately a factor 10.
If you dont need long distances between PLC and HMI, then the simplest is to connect the HMI to the MPI port.
Agree with Jesper and Soony, drives and distributed I/o is time-critical compared to HMI. And to reduce network load, separate them.
I recently inherited some 5/04 CPUs and a single 5/02 CPU that I need to pull the programs from. The 5/04 CPUs didn't pose any problems. I...
3,055
Hi, I have AB Micro820 PLC (2080-LC20-20QBB) which, acc. to the specs, can be both Ethernet/IP master and slave. I need it to be a master and...
2,221
Hello Guys, can you give me a tip? I am designing a Filter Press Station and I can't afford to buy HMI panels so I am going to use my PC as HMI...
2,076
Hi Gents, this is a tricky one. I am waiting to receive an actual Modicon M340 PLC, but I would like to test my code. Is it possible to connect...
5,172
I was wondering in you could gain access of a plc that is connected by dial-up modem on one end and me through the internet on the other ..is...
2,434
