Is is remotely possible to connect a plc???
mer
Dec 2009
Asheville nc
59
I was wondering in you could gain access of a plc that is connected by dial-up modem on one end and me through the internet on the other ..is their a program available to dial that modem VIA/enternet insted of modem to modem connection thanks in advance ......
The short answer is "Yes, but..." It is possible depending on the rest of your system. Generically, it's impossible to answer your question without knowing your system.
What kind of PLC?
What kind of ethernet infrastructure do you have in place to that PLC?
SKIP the Dial-Up Modem
Dial up MODEMS are 1980 technology. They require POTS (Plain Old Telephone Service). POTS amounts to a pair of analog copper wires. Red Green TIP RING.
A. Most people don't even have the availabilty or the money to just Have have a POTS line sitting there at $100.00 per month (just in case)
B. Analog modems are too slow for real-time PLC diagnostics.
You need to be looking at VPN via Internet. The Plant IT guy can open up a secure portal for you to access the intendend machine via thier corporate intranet, allowing you only a pipline to your intended target, and exclude access to corporate sensitive areas.
I have to agree with Plastic, VPN is the only way to go. Just yesterday we had a problem with a motion controller, set up a VPN connection on my laptop, connected to the controller and the OEM was connected to the controller, all in a space of a half hour
Edit: and you can see what the OEM is doing, that way you can learn more abouth the equipment
I agree so and so...
sometimes - also on older systems - you need a serial line.
once we have been checking out this but in the end we did not use it....
Maybe helps.
http://www.moxa.com/product/nport_5110.htm
br
bb
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
113
Hi all Trying to remotely connect to a TIA Portal PLC. I can ping it without a problem but can't get my software to connect. I've opened port...
345
Hello brothers We are contacting you because an error like [display change is currently controlled remotely] occurred while using the equipment we...
215
I've asked this before but I still couldn't make it work. I just can't envision a solution. Local RTU has a screen to set a handful of...
18
1,572
Hi guys, I'm a beginner in this field, but i have knowledge on IT i want to give a help to my best friend for his SIMATIC Microbox PC that he...
1,097
