Is Siemens SCALANCE S615 The Right Tool ?
rtgibson
May 2012
Barnsley
44
Hi All,
Quick sanity check - got a PLC addressed as 10.34.62.172 - we don't want to change this address but the factory want to access some data via OPCScout from a computer on the LAN in the address range 192.168.0.x.
Is the Scalence S615 the right tool for doing what I believe is called NAT (Network address translation) - so I can have one side of the S615 addressed as 192.168.0.x and the other side addressed as 10.34.62.x - so then they can point OPCScout towards the 192.168.0.x addresses and with a bit of config traffic will pass backwards and forwards to the PLC like magic ?
Russ
Hi All,
Russ
I've used that device in very similar situations quite a few times. Should work fine.
Make sure you look at the firewall settings in addition to the NAT; if they don't agree, you won't succeed.
Hi Ant
Sorry but I failed miserably and didn't get it to work.... I ended up having to leave site and leave it in the hands of their own automation engineers (we were only on site for a couple of days), haven't heard anything since. By comparison we've done 4 or 5 jobs since on AB gear and had their NATR device up and working within minutes....
Hi all, I have some difficulties with programming a NAT config in my Scalance SC636-2C When programming the NAT-table i'm not able to reach my...
201
Hi folks, I am struggling quite lot with NAT in Scalance switch XC208. Main task is to isolate lan and production network. I would like to...
4,964
Hi all, I'm having an issue with the setup of the NAT function of a Siemens S602 Scalance. I already have a working NAT functionality (see pic in...
2,950
Hi all, First a heads up, this is my first time working with Siemens product so please bare with me. We are testing the Siemens Scalance W700...
3,224
Hello Experts!!! I am working on Siemens Scalance M874-2 GSM Modem. I have successfully configured the Modem using WBM for SMS Application and...
3,045
