Is there a better way?
John Morris
Sep 2015
San Antonio
692
Good Morning all
L30ER, RSLogix 5000 Mini, 1769 IQ16 (8mS OFF/ON)
I have 6 actuators, using a IQ16 to read the 24v OFF/ON pulses of the encoder feedback. (It's within range of the cards capability)
According to other relevant sources the way to do this is with a periodic task.
Are there any other ways to achieve and compile the pulse feedback.
Any and all appreciated
Thank you for your time with this.
We put encoder counters in the Periodic Task with a higher priority and execution time that guarantees no pulses are missed.
Hmm,
No not really, but all the control is in the subroutine in the main.
My thought was just to read pulses from the actuator, count them, and import that back to the subroutine controlling the output to the actuator.
My brain hurts
This is the scenario. I want the actuators to go to three defined positions. Retracted, somewhere in the middle, and somewhere towards the end. ( I'll clear that up closer to the end of the build) These only get set once during the process then retract after its complete.
If I create a periodic task, can I......receive pulses, process, and control output all from inside the periodic.
Next, I have six actuators, can all of them be assigned to one periodic or should I use one task for each actuator.
I'm gonna go eat some aspirin now...............
My brain hurts
Try reducing stress in your life, and better regulating your coffee mg/hr
Yes. Think of it exactly like a continuous task, except it executes at a fixed rate.
All in one.
Noted.
Reducing caffeine intake = some has to die
Headache is coming from trying to learn a new language, and think in 3D at a higher level.
That, and it has to go on line in six days.
You've helped quite a bit and I appreciate your time
Thank you
Good Afternoon , It seems like we always have problems with using Type J Thermocouples with our slip rings . Would using a RTD at 10...
1,652
I am beginner in B&R Automation Studio and TIA Portal. Have an experience in electrical part of PLC cabinets. Now its time to get a new skills...
1,681
Bla Bla Bla, why doesn't it work, l need help and l don't understand PLC's. Or better they understand everything, but can't understand +1 -1 = 6...
22
6,025
I rarely need to add a network card to the drives we install... very rarely. But my sales-guy said he needs to quote a network-connected ACH580...
2,614
I'm currently on a research project where I can send tag read & write requests to both SLC as well as CLX controllers. Presently, there's no...
2,415
