Is there a "Wait For" in C programming?
But in seriousness, for C waitFor is done like this
while ( !inPos )
// do nothing
Came late to the thread and others have pointed the mistake with this approach.
In C programming, if possible (which is not very common), you would always add a timeout in that while loop.
Either by adding a variable that gets incremented inside the while or by taking the time it first arrived at that point and compare it against the system's clock.
Endless loop weekend calls are the best! Of course they never occur when you're at work.
can cross that off my list...
Hi everybody, not sure if anyone else has experienced this. I have been reaching out to Rockwell Techconnect this morning to try to ask a simple...
2,387
Fairly new to using this software. Working on making some changes with a trend client for better UI. I'm currently working on a setup where I have...
4,669
Good Morning , Sorry for the dumb question. I need to change a WAIT time from .5 to .2 . I change it with the teach pendant, but it goes back...
3,265
Windows 7 Enterprise RS Logix V28.02 This is a software issue, that is causing me a lot of pain in RsLogix and re-installs don't seems to be...
1,643
Hi. I'm writing an CODESYS program with ST. In diffrent parts of my main program i need my program to pause for a while and continue running...
10,239
