Is there any way to access the disk I/O variables in Vijio citect HMI??
HANYWEPCO
Oct 2009
UAE
Is there any way to access the disk I/O variables in citect V5.5, there is one tag available in the variables.dbf and it is defined as disk I/O tag and I want to know what is the source of this tag and from where it is originated ?? I found CDK file that can not be open..
The source is the Disk PLC device, its just a virtual PLC.
Yes,but if I need to know this tag how or where calculated in the harddisk ,where exactly the calculation is done on the harddisk??In which file or folder??
The value is held in the cdk file, if there is any calculation it will be done in Cicode etc, think of a disk PLC as just a holding place for tags, there is no PLC functionality attached to it
Do a search and see where the tag is used.
HI, I'm new to PLCs and rslogix. I was concerned about the floppy getting messed up so I tried to copy the license before I read that it will...
2,552
Hello ! I used to have a wireless access point that I could plug into a PLC network and set it with an IP address that fit onto my networks...
108
Hi Siemens guys! I am experiencing SF fault on our S7-300 (6ES7 315-2AH14-0AB0) CPU from time to time. I've checked the diagnostic buffer and...
223
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
112
I have to provide remote access and control to a touch screen. I was thinking about using Weintek and the Weincloud. Does anyone know if this is...
678
