isolating a bit
jimcav
Dec 2004
new jersey
229
I am using rs logix 5000 with an l61 processor. i want to change the status of a single bit in a shift register without changing anything else.
thx jim cav
If you know exactly which bit you wish to change you can use the standard logic blocks with a mask.
For example, If you have an integer with bit pattern
1100 1100 1100 1111
and you just want to set bit #3,
Then just use an OR block with a mask of 0000 0000 0000 1000
Actually, I showed you the hard way.
All you really need to do is reference your tag at the bit level as a set or reset.
If you tag is a DINT named Cat
For example SET Cat.4
OTL DintTag.1
DintTat.1
--------(L)--
Another way to do it (works well if the bit number is variable) CPT DintTag (DintTag OR 2**VAR) will set and CPT DintTag (DintTag AND NOT(2**VAR)) will clear.
Hey folks, Hardware: *=Must use these devices. Allen Bradley 1734-AENTR (Dual Ethernet Adapter)* Allen Bradley 1734-IE8C (8Ch Analog Input...
726
When a new machine comes into our facility the PLCs and Variable Frequency drives typically come with their IP addresses in the 192.168.1.XX or...
6,155
I am upgrading from device-net to Ethernet. We keep try to keep our distributed IO off of our business network by using an Ethernet bridge on our...
3,988
Hi,I have a question about isolating a control network from the plant Vlan network. In a new project the control network would have a Compactlogix...
3,325
Hey all, long time lurker for help, first time poster. We're getting ready to install an OPC data collection package on about 120 pieces of...
2,262
