Issue of PG/PC interface
ggchavhan
Nov 2006
pune
135
Dear All
I have Windows 7 Proffessional 64 bit. I installed Simatic Manager V5.5 Sp1, everything fine except PG/PC Interface.
I want to connect thru USB MPI adaptor, but it is showing PC Adaptor (MPI).1 This .1 extention is for all the drivers.
If I select that it dont show properties of the drivers.
It works fine with Windows 7 Ultimate 32 bit.
My question is that, is it issue of Windows 7 Proffessionl 64 bit?
if not
What is the solution??
I have a 1761-net-ini connected to a slc504. I have been talking to it wireless over a bridge, for about a year. The wireless is very unstable, so...
2,281
Hi Folks, I am not able to communicate to BEI Ideacod Absolute encoder with the Counter Module. Issue is as i Enable Direct Enable command in...
2,455
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
45
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
146
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
157
