In the Controller Organizer on the left, point your cursor at the very bottom and scoot up the "I/O tree" a little so you can see the Status for each of the things you highlight in that I/O tree.
When you highlight the PowerFlex 525 with the yellow exclamation triangle, you should see information that shows you the status of the I/O connection, and a reason why it is not running.
There should be a Description, a Status, and a Module Fault.
This might be a matching / keying issue, or it might be something else. The Status and Module Fault will tell you for sure.
Non-technical input: Keying and matching are so picky because of the high risk of connecting a device to the network with the wrong network address during maintenance or troubleshooting. "Thou Shalt Not Turn On The Wrong Motor" is a Commandment at Rockwell.
