Issues Controlling Stepper Motor Driver with Eaton PLC
celmassry
May 2023
Santa Ana
Hello.
I am using the following:
Eaton E4-AC-12RXP PLC
I am trying to control the CL86T which controls a Closed-Loop Stepper motor.
I am using Eaton Easysoft 8.0 on firmware 1.4.
I tried to program the plc using Ladder Logic.
This is the link that all the necessary files to program this.
https://www.dropbox.com/scl/fo/s2sgngxe0i4lr977lxbfl/h?dl=0&rlkey=jfoppce7jf73cqbd2jgv9kyjb
it has the electrical schematic, a couple programs that I have made on the eaysoft software and some user manuals of the cl86T.
My overall goal is just to control the stepper motor in a clockwise and counterclockwise fashion.
Any help would greatly be appreciated.
Thanks,
Christian
You need to enable the DIR & EN contacts before the pulse, the pulses must be 50% duty cycle & generally quit a high speed, not used the Eaton but I have done it on Mitsubishi the pulses need to be high speed for a reasonable velosity.
Dumb question.. would the dir and enable be a negated contactor while the pulse be a basic contactor?
or this is with the impulse relay..
Hello, I am currently in the final week of my internship and I have encountered issues with communication between a PowerFlex 700 variable...
56
152
69
I have an Allen Bradley temperature switch that I am trying to use in studio 5000. I am getting the message "Unable to interpret the IODD file"...
97
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
260
