Glazedgater
The issue we have is that the IT2I thermocouple card and the RTD temperature sensor card connected through a point IO AENTR is constantly trying to connect then faults out.
The Point IO itself connects with no issue and I have tried each of these cards by itself (Adjusting chassis size each time).
Through the webserver you are able to see the IO module and on studio it is picking up the serial number:
Things we tried:
Tried various firmware revisions, but can only change the minor revision as this is hardcoded to series B which is revision 5.
Tried 2 different point IO bases
Tried 3 different IT2I cards
Tried 2 different thermocouples
Installed new add on profiles
Made sure that the correct chassis size is in the webserver and PLC
Module is visible in RS linx!
Hardware/Software:
Studio 5000 V32
AENTR/B Point IO V5.019
IT2I card with IT2I base V 3.014
Standard dumb switch
L72 PLC
ENBT ethernet card
Could this issue be related to it needing a DLR as it is a 2 port point IO?
Things we tried:
Hardware/Software:
Studio 5000 V32
L72 PLC
ENBT ethernet card
