janner_10
First time using a point IO TC Input module.
I am using a R Type TC.
Config is set to Celcius & Type R obviously.
However both TCs are showing a reading of -50 or so.
Both TCs are wired directly into terms 4&5 and 6&7 as per the manual.
I note I do not have the 1734-RTBCJC terminal block, Am I correct in assuming this is essential hence my erroneous readings?
