Journeyman Level in PLC's
jtashaffer
Aug 2009
KY
415
I just saw a job posting that said you had to be journeyman level in electrical, pluming, carpentry, PLC's and so on. What is considered journeyman level in PlC programing?
I would say that depeds...
Some people work at a factory for 10 years doing the same things over and over again, on the same machines with the same brands of PLC. While they might be very good at what they're doing they don't really get any experience in other fields.
well, if you apply the "common, ordinary, dictionary" definitions:
(1) an "apprentice" is someone who is still learning a certain trade – and whose work must be supervised by someone more knowledgeable ...
(2) a "journeyman" has gained enough knowledge and experience in a certain trade to be allowed to work unsupervised ...
(3) a "master" has gained enough knowledge and experience in a certain trade to be considered qualified to teach it to others ...
so ...
going further: in my personal opinion (for what it's worth) a "journeyman" should be able to satisfactorily handle an assigned project on his/her own – without constant supervision ... in simplest terms: "here, take the ball and run with it – and let me know when you're finished" ...
your original question wasn't quite clear ... did the job posting say:
(a) "journeyman level in PLCs" ... or ...
(b) "journeyman level in PLC programming" ...
based on your answer, there could be a significant difference in the specific job skills that an applicant would be required to have ...
looking at the other requirements that you posted (electrical, plumbing, carpentry) I'd be willing to bet that "PLC programming skills" are not really what this particular employer is looking for ... smart money says that the job involves something more along the lines of: "go find out why the PLC won't turn the pump on – and get it working again" ...
aside: I apologize in advance if I have offended anyone with my gender-specific terminology ... I considered substituting "journeyperson" to be politically correct – but that seemed to be a trifle "overdone" ...
All, General Motors Corporation utilizes an PLC assessment for individuals applying for Journeyman Electrician positions. They utilize a 3rd...
2,829
I want to measure the tank level and get the sensor output to the PLC. Below are the details : Tank Height =0 - 3m, the sensor is stalled 0,2m...
639
Does anyone have RSLogix 5000 ladder diagram program of tank leveling (factory IO). Fill valve, discharge valve, set point, level, etc? I looked...
156
Hi, I am working on automating an industrial fabric shrinkage tester to replace its outdated electronics with a PLC. To get the tank's water level...
668
