just in case you know
sheryl86_ann
Jul 2008
laguna
142
A stepper motor has this terminal: PU, DR & MF.
I finally knew ( many threads posted already) what command to use in the PU and DR. Like in PU could use example: PLSY K800 K0 Y0 while in DR is only coil Y0 directly. The DR must have 2 signals to have the opposite direction set in PU.. However, my question is when and what command to use in MF (motor free) terminal.. THis effect will stop the motor in PU for example. When I tried programming it, the result will stop the motor with some noise. (ccw and cw together at the same time). If there must be a sensor to trigger the MF (i bet?), can anyone site me some programming sample here?
Also, have anyone has an english manual of YKA2404MA-A11 stepper motor drive?
Thank you very much for I am still bothered.
Sincerely,
Sheryl- Philippines
No sensor.
When a stepper motor stops, windings are still energized, holding it in place. For some applications, you may want to power off the motor so it can move freely. The MF command will turn off power to the motor.
Mr. Keithkyll:
Thanks!
Do you know sample commands use in programming the MF together with PU and DR?
(some threads posted previous days).
I figured I’d share my story of a Micro830 that I was banging my head on the wall over in case anyone ever runs into a freak fluke like this. I...
2,035
Hi everyone, new user so please forgive any breaches of etiquette. But in RSLogix how can you convert a string in the PLC to all lowercase and...
1,511
Hi all, I am facing issues with communication to the TruOne ATS of ABB via plc. Plc is M251 of SE. Majorly 2 issues: 1- writing to the modbus...
1,622
Hello everyone, I have recently started a new project using ST in Studio 5000. Previously, I have programmed in ST in Siemens. As i was writting...
2,929
1,405
