KEB-VFD is not tripping at higher current
We had a drive running a fan installed with a project. All drive settings related to motor protection were left at the factory default which was much higher than motor nameplate. When crud built up in the duct causing the fan to rub the sides, we smoked two motors before someone thought to check drive settings and properly set FLA / OL settings. I suspect there's a good chance you have something similar. I am not familiar with your particular drive model.
Hello, We have a new project using 12 (yes, 12...) KEB servo drives. We haven't ever used this drive yet, so I'm having some challenges to...
1,004
Hello, I am trying to connect to a KEB F5 using Combivis 6 via a USB-KEB cable but it says no device has been found. Anyone knows what could the...
1,142
Hello all, I am working on an old bagger that is giving a EUP fault which is undervoltage and intermittent. Electrical power cycles and gets the...
1,241
Hi everyone, I am facing a problem with my F5 series KEB Frequency drive. I have cobivis5 software and HSP5 service cable for interfacing. i am...
2,102
Morning All, Anyone had any experience with getting a KEB F5 Inverter to work on Profibus. I have an example program that works with Siemens S7...
1,816
