Keepware OPC to MOXA NPort 5210A
Kasperv79
Mar 2012
Copenhagen
48
Hej Guys.
Is anyone that has knowledge about setting up communication via ethernet from Keepware OPC server to MOXA NPORT?
the keepserver keep writting Socket error? I can Ping the IP in the NPORT.. ?
MOXA supprt is no help.
/Kasper.
So that's a Serial to Ethernet device right?
The basic way you'd use this to talk to a field device would be to connect directly from the Moxa to the Field Device and then map a software COM port using the Moxa software on the PC you're using to attempt communications with.
Then, use whatever software program(Kepware, programming software, Hyperterminal, etc etc) and point it at that software com port.
However, the first thing I would do is take my laptop with a physical com port to where the Moxa is and use THAT cable directly to verify my communication works to the field device. Only then would I hook it to the moxa, configure, and try troubleshooting.
Hi Guys. Our system is based on iFix and PLC 300/400. We recentle changed from using the Six driver from Proscada to Keepware server. After...
2,098
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
237
I know nothing about simaticnet OPC server. I do know Kepware. I would only ever scale raw to engineering in the PLC, but it is possible to scale...
219
If anyone has a crack for IBH OPC Server, please send it to: [email protected] Urgently. Thanks in advance!
133
Folks, I have a client with an old ABB Advant / MOD300 system (v14.4). Around y2k I installed the ABB Industrial IT MOD300 OPC Server 1.1/2...
184
