[Kepserver] S7-300 "Device is not responding"
ryrzu
Feb 2013
Gdańsk
24
Hello guys!
I have a problem with reading tags from S7-300 with 343 module.
I checked siemens communication settings hundred times with kepserver siemens suite manual. I checked kepsever settings too. But still i got message:
"Device 'chanel.device' with ID ipaddress is not responding"
I can ping S7-300 from kepserver server.
My guess was that because server is in subnet 150.110.100.X and device is in 192.168.0.X there could be some blockage on the way (Cisco switches) but IT department said nothing is blocked.
What should i check/do to find reason of the problem? Tommorow I'll try to connect directly to one of S7-300 and i will try to connect it to kepserver on my laptops virtual machine server. What else should i try?
The absolutely, positively best thing to do is to call KepWare. They've got outstanding tech support.
That's what I do.
Good luck,
Yosi
Hi ! I search the forum however still not find the solution My professor told me to communicate s7300 with kepserver, then do the same thing...
2,822
Is there a way to read an array from S7-300 ? The Kepserver documentation on S7-200 was very clear about the syntax for accessing an array (of...
3,626
Hi all, I was trying to communicate FX3GE PLC with KEPServer / Kepware via UDP protocol but did not succeed. Does anybody has any solution or...
1,079
Hello PLCtalk community, I force to 1 bits in System Platform that are read by KepServer, and for some reason other bits are going down to zero...
3,472
I have nuisance alarm that comes and goes. Doesn't seem to stay longer for a few seconds, is there any way I can somehow add a time delay or...
1,512
