Kepserver v5.3 --> v4.5
jeffy
Jun 2010
Auckland
35
Hi everyone,
Regarding Kepserver; when i open up a project file (.pfe format) that was edited in Kepserver v5.3; i am unable to load the same file in Kepserver v4.5.
What is the best way for me to be able to use this v5.3 file in v4.5? Is there a conversion process for the file? is there such thing? Any input appreciated. Thank you folks in advance.
If you have access to both versions then export the tags to excel from both systems (maybe create a dummy for the one you want to convert to) look at the format then paste the data from one to the other add or delete as required for the fields then import.
However this is not the whole project so some manual configuration will be required.
For me it was quicker to convert using import/export than to trawl the net finding a solution.
Hi all, I was trying to communicate FX3GE PLC with KEPServer / Kepware via UDP protocol but did not succeed. Does anybody has any solution or...
1,065
Hello PLCtalk community, I force to 1 bits in System Platform that are read by KepServer, and for some reason other bits are going down to zero...
3,467
I have nuisance alarm that comes and goes. Doesn't seem to stay longer for a few seconds, is there any way I can somehow add a time delay or...
1,506
Hello. I have an existing Wonderware system connected to existing SLC500 PLC /Flow Computers / RTU as shown in the attached Pic. And Existing...
1,694
I have ControlLogix L71 on ethernet. I want to send data to another Third party device using Kepserver. DO you have any idea how much data can I...
2,457
