Ketema LP Chiller Package
anaalmansuri
Oct 2013
Libya
Hi Guys,
I have this Ketema Dual Compressor Chiller Package running Horner PLC type OSC-100.
Do anyone have seen similar package anywhere else in the globe. I really need copy of the ladder code
Any suggestions please
Regards
Qasem
Horner OCS units use a programming package called Cscape. This is offered as a free download.
http://www.horner-apg.com/en/download/ocs.aspx
I have only programmed the OCS XL4 unit and not the older models. The link above shows the download link for Cscape for Classic OCS. This may be what you are looking to use to retrieve the program.
Note: The program may be password protected.
I would contact Horner to verify if this is the correct software.
Regards,
Thanks Gentlemen,
I have installed the software CScape and managed to communicate with the PLC but unfortunately the code is missing. It has been deleted accidentally by someone.
See the massage on the LCD
Sorry if this is slightly off topic, but I know you guys work with all sorts of different equipment. I have been tasked with upgrading our...
1,940
Hi guys does any one have epxperience on Prasad gwk chillers. We hàve a welco 125L chiller. We do not have a instruction manual. There is a fbu...
1,572
This is my first attempt at RS-232 communication. I am trying to communicate with a Poly-science Chiller using a MicroLogix 1100. I am using the...
18
6,333
Hi can anyone recommend the best way to program a 4 stage chiller (actually 2x 4 stage chillers in parallel). should I keep it simple and look at...
2,703
When looking a chiller eqipment electrical specs what are? The first one is a given but i am not sure about the other two FLA - FULL LOAD...
1,507
