Keyboard settings in RSlogix500
EnderTao
Jan 2023
Porsgrunn
Hello, I am currently taking a course on plc programming and in the course rslogix 500 is being used. I am however having a problem since it keeps changing the keyboard language to english(USA) every time i type in it and the key placements and binds are different than the layout i have on my keyboard. Has anyone had the same issue? And if so does anyone have a solution?
Now i know i dont need to use the softwere since its just a course, but since it is part of it i want to actually use it.
appriciate it if you take your time to help me out :)
I'm not sure that I understand the question. You mention that the keyboard is laid out differently (perhaps qwerty versus dvorak or something similar?)
Or maybe you are talking about the keyboard shortcuts?
At a guess, I'll talk about this stuff:
- RSLogix500 (at least as far as I can find) is just a program.
- Windows takes care of the keyboard mapping.
- In the install for RSLogix500, like most of the rockwell products, it asks what language you want to use. I have gotten that wrong in the past by fat-fingering the keyboard ... and I ended up uninstalling using windows uninstall .. then re-installing with the correct language.
If I got it wrong, please explain and maybe include a screen snapshot?
Thank you guys for answering. Ill try to clear up the problem and attach some images as well.
I have a Norwegian keyboard which is pretty similar to a traditional QWERTY keyboard except that since we have some extra letters we have moved the ":" and ";" around along with some other symbols. The problem i am having is when i click a component (attached file "compnent.png") it changes from norwegian keyboard (attached file "nob.png") to english usa keyboard (attached file "Eng") even tho i dont have that keyboard language installed on my computer.
I have tried a bunch of stuff, including the link given, in the windows settings, but it still changes.
I also tried reinstalling the softwere, but i cant seem to see anywere were i can change the language. I attached a file of what it looks like when i go into costum setup in the installer.
Once again i wanna thank you for helping me since its pretty hard to get in contact with rockwell themselfs about the issue.
Hi, I'm using TIA Portal V17 on Windows 11 (Runtime), and I'm facing an issue where the on-screen keyboard is partially off-screen, making it...
1,098
I have a numeric input field on my HMI. That field is being focused and written to by a macro keyboard so the operator doesn't actually enter a...
753
Hello. Is there a way to bind keyboard keys on the computer running the simulation of the PLC so that you can emulate button press etc during...
728
Is there a tag properties keyboard shortcut in RSLogix 5000 for an existing selected tag? I know Ctrl+W will allow you to create a new tag. But...
2,430
I am gearing back up my Rockwell and GE/Emerson setup and building my new macro keyboard. What is everyone's favorite studio 5000 and GE proficy...
1,303
