Keyence RV3 Analog Sensor Controller
Apr 2002
Just a bit northeast of nowhere
1,117
Hi all!
I'm using one of these little beige boxes to measure a position with laser sensors, and send a "go/no-go" to the SLC. On the back of the box are two inputs, EXT1 and EXT2. According to the manual, you can connect these inputs to GND in a binary format to select from one of four sets of tolerances (HI-LO values).
Well, they aren't working. I contacted Keyence, and they tell me the inputs need to be enabled. There is nothing, repeat, nothing abouot enabling these inputs in the manual. On the tech's suggestion, I tried locking out the front panel with the DIP switch setting, but that did not enable the inputs either.
My question : has anybody ever used one of these before, and if so, how did you enable the inputs? It's possible the inputs are damaged, but since the rest of the unit works fine, I don't believe it's the case.
Thanks!
TM
63
Hi everybody, I would like to know if anybody here has already programmed with a LR-TB keyence on Io Link on a Rockwell PLC? And perhaps have...
90
Hi everybody, Is anybody here still have programmed a Keyence sensor LR-TB2000CL and used it as io link material in studio 5000. I would like to...
103
Hello all I've got a cell with four Keyence IV3 cameras that are saving images to a FTP server, we are also labeling the parts with a time date...
285
I will find cable series but I don't know for fs260 model, kindly suggestions and help to me for connect cable
120
