Kinetic 5500 - Absolute Move - MAM PC Bit Understanding
Sensorless
Feb 2021
Ontario
Hello all,
So I have a linear actuator connected to my servo and I command an absolute move to a position, for example 80mm. Now at 75mm position my servo starts to perform some work (cutting a pipe). I want my servo to return home when it is done cutting the pipe which is the 80mm position.
The problem I have is when I am at 79.75mm, my MAM.PC bit turns on and the instruction thinks the move is complete, when in fact it is not. My position lock is set to 0.0249mm so that is not the issue. I have datalogged my position error which equals 0.25mm at this time. It seems to me that the MAM.PC bit is being set when the position + position error = commanded position.
Can anyone explain to me if this is in fact correct and if so, why?
Thank-you
Hello, Currently my Kinetic 350 having an error of F43. I checked in the manual as it said: An attempt was made to enable the axis through...
864
Hello guys, Frequently servo drive stops with fault code S46.Please can you tell me what could be the reason. Thanks and kind regards...
897
Hello guys, Please could you tell me what is the reason for E05 fault. Also, I observed reset after fault is disappear. Kind could you guide...
1,550
Hey people! For a school project, I and a friend have a 1734-VHSC24 connected to an encoder. Simultaneously we have 2 x kinetix 5700 with servo...
1,933
Hate to ask so many questions. But i have found this site is better than tech connect. I have a kinetic 300 in a machine and we making some...
1,543
