kinetix 3
hackj0632
Jul 2009
wi
33
i have a kinetixs 3 drive that i am using for preset indexing. after homing when i try to index an incremental move i receive a excess position error. error 19. i have no idea why this is happening. in the altraware software i have disabled all limit switches and set all position limits to zero. i tried entering position limits of 999999999 with no change. any ideas would be appreciated
thanks
Hello all I was trying to autotune a Kinetix 5100, I got an encoder fault and it says to check the wiring. I remove the 24 volts from drive to...
27
Hello everybody, I have Kinetix 5500 (2198-H040-ERS). I'm having issue with this drive. (I believe it's the drive/Kinetix and need confirmation)...
40
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
155
Good day: I am wondering if anyone has experience with the Kinetix 5500 S33 Fault. I have 3 drives in a group set as follows: 2198-H025-ERS2...
184
Kindly, we have the following configuration fault on a Kinetix 5700 axis. It only appears when we go online on the Plc. We are just starting the...
118
