Kinetix 6000 servo master slave problem
nightline
Feb 2010
Prinsenbeek
425
Gents,
I've an Allen Bradley Kinetix 6000 Sercos servo system with 2 motors on a rigid construction.
Both motors have the same gear ratio to the construction.
I connect both motors with a MAG instruction with a ratio 1:1.
When I start a motion instruction there appears a great difference in torque feedback between both motors, something like 250 for the master and 50 for the slave.
What can cause this?
Thanks in advance!
Jack
In meantime, I had the same idea, and programmed it already.
I will test it today.
I'm not sure if I use the right steps on this system. This is what I do:
-fault reset all drives
-MSO on both drives
-MAG drive 1 master and drive 2 slave
-MAH on drive 1 ( bi directional forward ) When completed:
-MAH on drive 2 ( immediately )
-2x MAG both drives to the Virtual Master
-several MAM's for all movements
Is this the right sequence to get it all work together?
Hello All I have a machine built in 2013 but never commissioned. I have it almost complete. It has 2 Kinetix 6000's with a CompactLogix L43 with...
1,201
The homing watchdog timer preset was changed to 60 sec from 30 sec due to servo homing taking too long. The home offset is around 180 degrees...
1,930
Gents, I'm asked to check if an SEW servo motor with Hiperface encoder can be used with an Kinetix 6000 sercos servo drive. When I check the...
3,504
Hey everyone, Recently our maintenance department has been having all kinds of trouble with servo motors and i would like to build a servo test...
2,192
Good Morning , We are going to need to change a gearbox that as a MPL-B540K-MJ24AA connected to it. The gearbox is 19.5 : 1. The problem is...
4,390
