Kinetix 6000 with SEW servo motor?
nightline
Feb 2010
Prinsenbeek
425
Gents,
I'm asked to check if an SEW servo motor with Hiperface encoder can be used with an Kinetix 6000 sercos servo drive.
When I check the manual, an Hiperface seems to be supported by this type of drive.
When I look in the software (Studio 5000) in the configuratie of servo proporties, I can select 10 types of encoders but non of them is a Hiperface unless it's called different.
Can somebody shine some light on this?
The SEW motor is an: CMP40M/BP/KY/AK0H/SB.
The drive is an:2094-BM1 or 2 rev. 1.135
Jack
If I set the SRS or SRM encoder type, the cycles are set default at 1024, and I've not the possibility to modify this to the needed 4096.
Is there a work around known?
Hmm just double checked and I can't change it either. Are you sure you need 4096? I don't think that number is the same as pulses per rev. I think it's full cycles and so you end up with a lot more pulses per rev than you might think.
Does it work with it set to 1024? I think for srs that is 32k pulses and srm is more like 134 million
Well we are building a car for carnaval, and all the controls servo VFD's is stuff we get from companies. So for long time we have the Kinetix 6000 servo rack, and for some moves it was nice to use the very small geared servo's from the SEW brand which we have. And these motors are equiped with the 4096 Hiperface encoders.
Hmm yeah I am not sure, then. I would talk to your AB distributor to get support.
Howdy guys - Looking for some insight on the MAM instruction. Had an interesting one today: I performed a controller upgrade on an older system...
440
Hello everyone: I am looking at the possibility of migrating Kinetix 6000 to Kinetix 5700(460V 3 phase). Reviewing the drive catalog, I have the...
1,146
We have two similar pieces of equipment, one of them uses a Kinetix 6000 for an axis and the other uses a Kinetix 350. When power is removed...
848
Hello All I have a machine built in 2013 but never commissioned. I have it almost complete. It has 2 Kinetix 6000's with a CompactLogix L43 with...
1,202
Trying to configure the 2nd drive on this machine. It is being difficult. I have the gains speed encoder data all with good data. when I try to...
1,850
