Kinetix300 Communications With ML1400
gbradley
Apr 2002
Corona, Ca.
1,637
I have a Kinetix 300 Servo Drive (2097-V33PR3)I want to communicate with Micrologix 1400 (1766-L32AWAA)
I ordered the Allen Bradley Switch,(1783-US05T) but in the Meantime, while I wait for it to arrive, can I use a simple switch in it's place?
No problem. Because the MicroLogix won't be using I/O messaging to communicate with the servo controller, you don't need to be concerned with constraining multicast traffic.
The only things you lose with an ordinary switch in this case are diagnostics and durability.
Thanks, I'm trying to get it to work now, but I'm afraid that I may need to have the Motor leads, and Feedback cables connected and powered up first.
Got it.
I am able to go online with the Drive and download the Java based MotionView 3.36.
I forgot that you need to cycle the power after changing the I.P. address.
Thanks Ken
Hello, I am a bit familiar with PLC programming, but I've never dealt with servo drives before. I am having a hard time even establishing a comm...
1,372
Hello everyone, I'm currently losing my mind with the loss of home position of a MPL-B1530U servo motor, controlled by a Kinetix300, with...
2,172
I am encountering a problem with my Micrologix1400 and Kinetix300 set up. The problem occurs when trying to job the motor, on the first push of...
1,434
Doing a project where I will be using an AB Kinetix300 Servo Controller for a Rotary Cutter. I have never done the configuration/setting up of any...
21,141
Kinetix 300 Servo Drive (2097-V33PR3) In the MotionView OnBoard software, I can change the drive mode to EtherNet/IP External Reference...
5,466
