Kinetix6000 E62
Benyamin
Mar 2012
Dallas
67
Hello,
I got E62 on Kinetix6000 servo drive.
I have checked feedback cable end to end all are good connection.
There are 9 wires connected.
In this case, how we could tell that encoder bad or something else.
Also how to fix the problem.
Thank you,
Benyamin
Kinetix 6000 Error E62
As I mentioned before, I have triple check feedback cable including all connection.
There is no wiring open, shorted or missing.
Are there any possibilities cause E62 and how to solve this problem.
Any help will be appreciated.
Thank you,
Benyamin
As I mentioned before, I have triple check feedback cable including all connections.
Pin by pin. Each Pin, from one end to another end all are good.
There are 9 wires soldered in good connection, electrically and mechanically.
This happened when the machine was running and suddenly stopped
Thank you,
Benyamin
Hello all,
After replacing motor's encoder, E62 has gone, and Drive status Red light has gone.
But COMM and BUS Green Lights are still flashing.
7 segment display of Phase Status just stop on '3'.
In normal condition this Phase Status will shows '4'
On Sercos Module, all three Green Lights are flashing.
Any help will be very appreciate.
Thank you,
Benyamin
Hi, Expert: Is there any possible MAM PC bit turning on before reaching the position? Thanks!
2,007
Regarding sercos motor control I am a complete novice so i'm a little out of my depth here. My issue is that I have 4off kinetix6000 servo drives...
2,080
What would be the reasons why the IAM module would open the contact for the Contactor Enable Relay (CED) on a Kinetix6000 drive. This is...
2,687
Hello, we are using mpl-8330p-sj24aa as a conveyor servo with kinetix6000 guard motion.And our plc platform is control logix5573.The conveyor is...
2,081
on one machine,roller circumference is 50cm,the gear ratio is 15:1.and driver is kinetix6000.i want realize the function is: if i write 5 in the...
2,011
