kinetix6000 guard motion
nihat dursun
Sep 2012
Istanbul
Hello,
we are using mpl-8330p-sj24aa as a conveyor servo with kinetix6000 guard motion.And our plc platform is control logix5573.The conveyor is rotating in one direction.One time we closed the main disconnect of the machine and machine was stopped before closing it.When we switched it back on and the started the machine , the conveyor started the rotate backwards.We stopped the machine , download the plc back-up program and the issue was resolved.But we could not detect source of the problem ..I wonder kinetix6000 firmware upgrade is permanent solution for us?Or can you help for this matter ? (in addition; after firmware upgrade , if we encounter like any problem so firmware downgrade is possible for kinetix6000 ?)Thanks in advance..Istanbul likes you..
Hi, Expert: Is there any possible MAM PC bit turning on before reaching the position? Thanks!
2,008
Hello, I got E62 on Kinetix6000 servo drive. I have checked feedback cable end to end all are good connection. There are 9 wires connected. In...
2,803
Regarding sercos motor control I am a complete novice so i'm a little out of my depth here. My issue is that I have 4off kinetix6000 servo drives...
2,082
What would be the reasons why the IAM module would open the contact for the Contactor Enable Relay (CED) on a Kinetix6000 drive. This is...
2,691
on one machine,roller circumference is 50cm,the gear ratio is 15:1.and driver is kinetix6000.i want realize the function is: if i write 5 in the...
2,011
