KTXD Card & Cables???
Heterodoxy
Mar 2003
Northwestern Tenn.
30
Just installed a ktxd card, have cables 1784-cp12 & cp13. But need to communicate with a PV550 (2711-B5A5) to update firmware. Which has a physical RS232 port with DH-485 protocol. In the ktxd user manual on pg. 4-3 it states to use Belden #9842 to construct custom cables for DH-485. And it gives AB publication numbers for the more information, but when I perform a search at ab.com it never comes up with the necessary documents. It would be nice to be able to get the pinout so that I can make my own DB9 Female (for PV) to Phoenix connector.
As if that’s not enough, I also have a friend who has a PV600 with DH-485. (T6C2) That has a long flat connection (sorry don’t know the correct terminology) and connects to a SLC 5/03 (RJ-45) through a 1747-C10 cable. Now the question:
If I cut up an extra 1747-C20 cable lying around. I should be able to make up my own 1784-CP14 cable if I can find the correct pinout for the 6-pin phoenix connector!
And with the other end I’m hoping to be able to make up a cable that I can talk with the PV600, if can find the right pinout for the long flat connector and the phoenix connector
Have preformed a search in this forum, and read through every thread that I thought might deal with this issue. With no luck! But with the brilliant minds that I know exist on this site. I’m sure one of you has the answer.
Thanks So Much
Heterodoxy
Your 2711-B5A5 unit's port is electrically RS-232, even though it uses the DH-485 protocol. You don't need a 1784-KTXD card for it, you just need an RS-232 port on your PC (COM1 on virtually all desktop PC's).
You just need a straight-through serial cable to download to the 2711-B5A5. Not a special cable, not an A-B cable, not a null-modem cable, just a cable with pins 1-8 tied directly to pins 1-8 on the other side.
The colloquial term around SLC users for that "wide, flat" DH485 connector is "AMP connector", just because that's the maker's name stamped on it. I don't know if it has another name. I always make my Phoenix -> PanelView cables plug into the RJ45 connector on PanelViews that have both types of plugs.
I have a fresh install of windows xp service pack 3 and have loaded line 2.54. I installed a pktxd card and drivers from the link disk and all is...
1,577
Hi, Can anyone help me regarding my issue with PKTXD card driver in Windows 7. There is no channel available when I tried to configure it in RSLinx.
2,683
Hi there I am looking for some help with an Allen Bradley 1784-PKTXD card, my hardware is as follows: Dell Precision 390 Tower PC (running clean...
3,481
I have a big problem when I install 2 1784-PKTXD on desktop. Desktop: Compaq PII, Windows NT 4.0. I setup the jumper 2 and 3 for 1784-PKTXD, 5...
2,723
Hey Guys, Need some help with this 1784-ktxd card that I am trying to get going in my office desktop. I have been trying different memory...
3,180
