Kuka robot gsd file
DANILO
Mar 2008
São Bernardo do Campo - SP
I'm working in a project in which I need to put 2 kuka robots as slaves in a profibus dp network.
The master is a wago ipc plc. My problem is that I still don't have the code of profibus card of the robots and I need the gsd file to make my profibus configuration in the plc.
I searched in kuka catalog CD and I found the following codes:
00-130-764 = PC card Profibus DP master / slave;
00-128-307 = Profibus Slave, Hilscher.
Does anybody have any gsd files of kuka robots pc cards?
Hi all, First time posting here. I have a Omron NX1P2-1040DT controller that I intend to use for a small project. I also have a KUKA robot that...
1,199
Hello, I need to establish a CIP safety communication to a KUKA KRC4 robot. The KUKA has the IP 192.168.11.53. I already established a standard...
10,290
Hello, I have a new project with a kuka robot. Does someone have to share a FB/FC in Step 7 to start and command a KUKA Robot? If is possible in...
1,951
Hello, I have to communicate with a KUKA robot (Type KRC4 with EthernetIP Interface). For that I use the Generic Ethernet Module with the...
6,823
Does anyone know the maximum length of the control cabinet cables (as supplied not self made) to the robot on a KUKA Robot (KR 40 PA) ? My KUKA...
4,579
