Tell you what Steve - lighten up - if I called you an idiot or a fool or otherwise insult you , then OK , but a simple joking comment was made -
So , if you want to take it like that , up to you . I thought this forum was all about replies in the plural , if I post something that is not clear , do you not have the right to question it ?
If you wish to be so pedantic , you didn't answer the question at all . The answer to the question is very simple :-
1 watt is 1 joule/second
1 joule is 1 volt * 1 Ampere
1 joule is 1 Newton Meter
1kW is 1000 watts
Very infrequently do we use BTU anymore , again , our clients prefer the use of SI units -
If someone doesn't know what a watt is , then a very simple explanation is in order - it is one of the most basic foundations of understanding necessary for electrical work - the relationship between Volts Amps and Watts is the first thing learnt in Physics at an early age .
You don't have to get the hump with me for giving it .
1kW is 1000 watts
