Ky-040
roxusa
Nov 2008
NJ
994
What is the best method to use 5vdc outputs like the Arduino with an ML1400.
I'm not working with Arduino but trying to incorporate the KY-040 encoder
to an ML1400. The KY-040 is only a 5vdc output and I'm hoping to use the high speed inputs from the 1400. Would I have to build my own Transistor board to convert the signal or is there something available.
I'm hoping someone has already done this. Thanks
I am trying to deal with fragmented data, and have been getting stuck. So far I am able to command the Fuchs VE Software version correctly and I...
174
Has anyone ever heard of this model PLC? It looks like a PLC-2, but I'm wondering if it the programming and communications are the same.
1,126
Hello everybody I'm try to find a way to get response from a 9040 Markem Imaje Printer after send an a massege like ACK 06h or NAK 21h anyone can...
7,156
are anyone here can help me to find out a way to send a message as a external variable to the printer ( 9040 ) from the PC over the Ethernet...
3,249
Hi all, This is a request for information on a very unusual setup, so I don't hold out much hope for a response. We have a HVAC control system...
1,216
