The 1769 CompactLogix Packaged Controllers Quick Start and User Manual, under 'Additional Resources' directs you to the Compact 8-Bit Low Resolution Analog I/O Combination Module User Manual, stating that: "This manual provides further detail regarding the use of the 1769-IF4XOF2 module and the embedded analog I/O."That's so crazy! How am I supposed to know 0-6 need to be masked? Is there a manual on this?
That manual then shows the layout of the input data file, with 0-6 as zero, 7-14 as data, and 15 as SGN.
It does claim that bits 0 to 6 are 'permanently set to zero by the module' however, which is apparently not true (at least for inputs that are embedded in the controller).
So it doesn't exactly tell you to mask them, but it certainly does show that bits 7-14 are the actual data you should be looking at.
