L32e ethernet bandwith question
jimcav
Dec 2004
new jersey
229
I am using a 1783-ems08t managed switch and the plc ( l32e ) is plugged into port 1 to me it seem that the plc is really slamming the network. when i log into the switch under alarm setup the plc is running at 48% and the other 5 items are at 10% or lower. is this ok or is the plc running high not sure please advise.
Thanks for the help
Jim Cav
I'm going to take a guess because you have not described your network.
The CompactLogix and ControlLogix make heavy use of multicasting to send frames from one to many (all the devices in your subnet). This allows all the nodes to share the data on the subnet but is quite bandwidth intensive on a 100K ethernet network. So those numbers look entirely within reason for an L32E. I've seen 100K ComapctLogix networks where ALL the bandwidth was consumed with only around 10 Ethernet/IP devices.
You might want to look at using your managed switch to minimize the size of your multicast domain if the other devices are not running Ethernet/IP. Or you might want to put a router in and further separate your domain between control, HMI, LAN and WAN. VLANs are a great way to break up your networks - but do require a router to bring them back together.
You can also control the frequency of the multicasting in RSLogix 5000. The default tends to be ridicously fast for some applications that just don't need to be updated all that fast (maybe Ethernet/IP drives?)
Good Day Everyone I could use some advice and/or direction on how to connect remotely using my Wifi to a 1769-L32e. I set up the Ethernet/IP while...
1,403
I am trying to address an issue with a L32E faulting the ethernet port when connected to the companies VLAN. I have a PLC network connected to a 5...
3,671
I have just purchase a new Compactlogix L32E Systems and have it configured for rs -232 communications and it works great.......however I'm in...
3,097
I am using 1769-L32E. but I have the problem about EtherNet Port as follows; 1. When I test RUN this CPU, I/O LED green blinking. but All...
20,298
Looking at a potential project that would be using multiple (4-8) L32E/L30ER and multiple (6-10) Micro 1400 controllers. I will need for all them...
3,916
