Wifi Ethernet comms to 1769-L32E
nitrofever301
Mar 2019
Valparaiso, IN
Good Day Everyone
I could use some advice and/or direction on how to connect remotely using my Wifi to a 1769-L32e. I set up the Ethernet/IP while I was onsite. I am working with the onsite IT/Tech to figure why I cannot connect. I may have some setting wrong in RSlinx. I am using RS5000 V19.1.
Dave
My PLC project I have been working on for a few years now has a new home. It is a Micrologix 1400 and I have a C-more Micro 6 inch panel...
1,978
Hi; We are going to install Micro820 PLCs (more than 20) at our different machines to get the production data at main server. The regular option...
1,750
I'm curious if anybody is using 802.11b or 11g to link their plcs and/or OITs in their plants. I've seen alot of activity in the proprietary...
3,412
I need an enclosure for wifi access points that will be outdoors. The antennas will mount outside the box but everything else inside. Standard...
157
Hello, I want to establish LTE communications (2 S7-1200) with common Workstation. All i have is 1200CPU with 6GK7243-7KX30-0XE0...
318
