Wifi Enclosure Selection
Tim Ganz
Dec 2010
Dallas, Texas
691
I need an enclosure for wifi access points that will be outdoors. The antennas will mount outside the box but everything else inside. Standard wifi enclosure is not large enough so trying to determine if best to go with steel, stainless, pvc or fiberglass or does it not matter since my antenna will mount outside?
Thinking of making antenna come out the bottom vs the top so there can never be any water entry even if the antenna seal fails in the future?
One thing you might consider in selecting the enclosure is weather conditions. PVC or Fiberglass would provide better cold weather insulation but stainless would be better when exposed to the sun.
Making the connections through the bottom of the enclosure would be best.
If I had my druthers, I'd say the less metal near the wireless the better, but environmental conditions would trump that concern.
Agree that bottom would probably be a good idea, with the caveat that you need to make sure it's appropriate for your antenna's radiation pattern.
Tim,
i would look for line of sight units. i used Ubiquiti that was almost 150 yards apart. we did have a power spike that took out the unit.
i replaced it with the same model and put in a new surge protector and is hasn't stopped in 5 years
james
Tim,
james
James
This will be a mesh network that is intended to support mobile HMI (tablets) around the plant with multiple mesh nodes about 15 nodes across the site.
Hello, I want to establish LTE communications (2 S7-1200) with common Workstation. All i have is 1200CPU with 6GK7243-7KX30-0XE0...
325
Have a project coming up which will use a tablet HMI in addition to the two fixed panels. Curious if anyone has a tablet/router/AccessPoint combo...
1,401
I have a customer that wants to make a system. Think garage door opener. That functional part is simple. They want to connect it to the customers...
1,646
My PLC project I have been working on for a few years now has a new home. It is a Micrologix 1400 and I have a C-more Micro 6 inch panel...
1,982
Good afternoon, I'm building a test station for temperature mapping that will log 12 data points to SQL via Open Automation Software. This station...
1,973
