Ethernet connection of Micro820 via WIFI
AB2005
Nov 2006
Lahore
318
Hi;
We are going to install Micro820 PLCs (more than 20) at our different machines to get the production data at main server. The regular option for LAN connection with each PLC is that we should lay LAN cables from Ethernet HUB to PLCs and connect these PLCs with LAN.
Is it possible to install a WIFI router/transmitter in center of department (connected with company LAN) and on the other hand, install a WIFI receiver with each PLC to connect it with company Ethernet network? Has anyone worked out for this option?
I think I would keep it wired and run them to one or two wifi connections... they have wifi repeaters but I have not used one that I would trust for industrial applications
It also depends on what you are doing and with the PLC's are they controlling and passing important data over the wifi?
WiFi technology has gotten very reliable over the past several years and depending on the topology and region of the world you are in it may be a very solid application or it could be poor at best (or everything in between). With the topology, if you’re going relativity short distances, line of sight is crystal clear and antenna will be located away from metal objects then it looks very good. If any one of those is compromised I’d stay away from it. As far as “region of the world” there are some places where some of the frequencies used in the latest standards aren’t allowed or are limited in output power and if that’s the case, again I’d stay away from it.
Having said all of that, another consideration is the amount of data you are planning on moving and the time frame that it needs to move in. If you need near real time data and/or lots of it that gets a lot harder to accomplish. If on the other hand you are looking to update a few tags every few seconds from each PLC then I’d go with Frequency Hopping Spread Spectrum 2.4GHz (unless this application is somewhere that 900MHz is available for use, then I’d use that). FHSS is much more robust and reliable than WiFi but it is also much (MUCH) slower with a much higher latency.
In short there really isn’t “one answer fits all”. It largely depends on the details of the application and where it’s located.
Hi all, My ethernet port on my laptop recently broke and I was hoping to just use a usb-c dongle in the mean time to go live on my PLC until I...
454
Hello, I've been trying to learn this a while now and still have not found out how this works. I have an Omron CJ2M PLC and an ABB ACS 355 VFD...
245
I have a running backup of Citect and plc and I want to make a spare PC station so I have installed the win XP and somatic net v6.0 and import the...
123
Hello all! I have some machines that run an SLC 5/03 and occasionally a fault is generated. Recent Example: A power supply wasn't screwed in...
421
Hello all. I have a 1769-L16ET-BB1B, LogixDesigner v.34.011, that was brand new, factory sealed. I connected via USB port and downloaded my...
17
2,567
