L32E Firmware Compatibility Issue
CAAJ
Dec 2014
Fairhaven, Ma
47
Hello All,
I am having trouble configuring my new L32E controller through RSlogix 5000. When trying to go online, I am receiving an error with the condition "Unable to connect to controller. The revision of the offline project and the controller's firmware are not compatible." Then it states that the offline project file I've created contains a firmware revision of 19.xx however the new controller with the IP address I've assigned has a firmware revision of 1.17. Should I just simply update the firmware? If so, where and what revision should I select? And should I change the projects revision or the controllers?
Any help would be much appreciated :D
Christian Acosta
JeremyM, thank you for providing the link. I was able to change the firmware on the controller!
New ControlLogix and CompactLogix controllers all seem to come with that 'default' firmware. So this is something you'll need to do anytime you get one.
I just found two old 1769-L32E controllers in the plant that I cannot go online with using my version of Studio 5000 (30.14). I've reached out to...
1,991
hello guys>> i have cpu compactlogix 1769-l32e and i have a program on my flash memory with extension p5k with version 17.004 (17.4)...
2,394
I have an L32E processor that is currently using RS Logix 20.01 software. It's been a while since I've touched Allen Bradley software, so before...
1,535
Not super familiar with OPC servers and how they scrape tag data. But the current system uses an old Kepware software package called KepServerE...
1,814
To make a long story short, I cannot update my LOGIX5000, came from a company long ago and far away, dont have all the info to update. I...
3,118
