Ladder Creation Bad in Mitsubishi PLC
Riyas Mohamed
Nov 2023
Dubai
17
Dear All,
I have an Mitsubishi PLC (FX1N-40MR) and PLC backup was taken and i compiled the program and its showing 0 error. then I tried to download the same program in that PLC and I can't download and it is showing error and check Program. In Tools I selected the 'check program' and it showing 'Ladder Creation Bad' Error Code:C9322. It showing 5 same error in different steps but In program only showing up to Step:111 but the error was showing like Step no: 112, 5587, 5589, 5595, 5597). But these steps are not showing in the program.
It could be that it was programmed in GXIEC originally, I have come across this in various ways, perhaps post your program also what software have you used to upload the code from the PLC i.e. GXDeveloper, GXWorks etc.
The problem is that for some reason it filled the rest of the program with NOP0 (seen this before) so it makes the program too large for the ram.
I have copied the code to a new GXworks session & saved it so it will now download to the PLC, I assume you have the correct PLC type i.e. the file you sent claims it is a FX1N
  • Updated.zip
Actually, just read your post again & the file you posted is not GXDeveloper but GXWorks2 I hope the file I posted you can open it (may depend on your version) if you do need it in GXDeveloper I can port it to that.
I got my PanelView Plus 7 working with a Micrologix 1500. How would I connect my laptop to the PanelView to view the ladder logic while operating...
117
please help me . I have to make this ladder diagram and I can’t figure it out :(
343
Hello, I am trying to replicate a piece of logic on the PLC5 onto an SEL RTAC. I am using ladder on SEL and FBD. I am having issue on the ladder...
229
Hi all. Is this the simplest way to debounce inputs in Ladder (there are 2 points being debounced here)? The TOF drives the tag. I'm expecting...
495
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
199
