hai guys i want to make this more interesting
by using counter,timer,set/reset or positive, negative coil its easy...
i want you guys to try it by using only normally open,close contact and coil
FYI
I used to train apprentices with this type of question.
HARD WIRE ONLY _ NO PLC)
design a 'Flip Flop' circuit that operates like this.
- EQUIPMENT LIST
- 1 Momentary Push button
- 3~5 control relays (4 pole) *only 3 relays needed*
- 1 light
- AIM
- when the button is pressed the light turns ON
- When the button is released the Light remains ON
- When the button is pressed again the Light turns Off
- When the Button is released the Light remains Off
then back to the beginning
the reason for this is to learn contact timing
PLC's, as Lancie1 has stated, all behave differently.
there is no easy, correct, one answer, but the understanding of the program is important.
one PLC will accept this following command
it flickers on and of with the scan rate - INTERNAL RELAYS ONLY.
A A
-------] [-------] / [-----------(A)
(ref: Fuji Microrex 80H)
