Ladder logic fix required
Tobester
Jul 2005
Melbourne
I'm a chemical engineer trying to be an electrical. I have a problem here with two automated valves feeding two tanks. I have been able to set them to switch when one tank is full and both open when both tanks are full. However I'm having trouble when they both empty at the same time. The logic requires one full and one empty for switching however in the off chance that both get emptied a valve needs to close. Can anyone suggest anything???
An Aussie Cheers
Bud, just choose one and if you have both tanks empty i.e. M6a and M6b, turn on Y508 (in parralel with its normal condition i.e. M6A). Just a note.. your really making a rod for your own back with Sets and Resets, just use a normal output with a latch, its so much easier to follow.
Stupid question
If the valves are feeding the tanks, why would you close them if the tank is empty?? What type of valve Energize to open?
Can you draw a mini P&ID, with Flow diagram would help......
Regards
PS SteveD is right this is what a self latching rung look like
Open valve condition == I1
Close valve condition == I2
Output to Valve == Q1
......I1.....................I2..................................... Q1
.....Q1
Q1 latches the rung when Open valve condition is high.
Circuit will latch till I2 is high and rung will be broken.
Q1 contact at bottem is called self retaining contact.
Thanks for that, gave the simple option a go and it seems to work fine. I'll have a look a revising the overall program and replacing with self latching rungs, when I'm confident enough to understand them.
Cheers'
I got my PanelView Plus 7 working with a Micrologix 1500. How would I connect my laptop to the PanelView to view the ladder logic while operating...
150
Hello, I am trying to replicate a piece of logic on the PLC5 onto an SEL RTAC. I am using ladder on SEL and FBD. I am having issue on the ladder...
238
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
204
Good morning crew! Ok my logic works but I am missing something. When the start button is pushed it should like the red light for 4sec then shut...
424
Working on project will update after it is completed.
358
