waggs
With a few pointers I can try to import the logic or screen. Not sure what I'm doin yet, but I'll see what I can do.
Bob
Bob
Please can you give the code in pdfHere is a short program of 2hATD that I've used alot. It isn't fancy but it does take into account two hand actuation and timed interlock(?) between the two PBs'. Depending on the use, we were making small component assembly machines, anti-repeat was added by looking at both PBs' having to be released, i.e., 'cycle complete'. Like I was taught, there are 1000 ways to skin a cat, you just have to find the one that makes the least mess. Hope this helps...I'm open to suggestions and ideas.
Bob
the timer should be set to trip in .3 seconds, although we have used .5 seconse. .3 seconds is to fast.
one thing you MUST consider is that the pushbuttons must have a way to be checked in the plc for release and contact breakage. that's what an anti tie down module looks for.
for example, banner otba5 pushbuttons (if my memory isn't faulty) has a set of n.o. and n.c. contacts.
regards,
james
