Ladder logic For Keyence Sensor
hurricaneapa
Jun 2021
Meadville
Looking for help on how to create the ladder logic to execute these steps below.
First, our set up is a Keyence IV2 sensor, connected through ethernet to an Allen Bradley Control logix PLC. I am able to execute the steps manually through the control tags on the RS logix 5000 software (by changing the 0 to 1). The sensor allows us to save up to 15 images. When we are ready to scan our parts, we will have a human to set up the initial good part under the sensor and take the image. For example, we may have to take 4 images of part A, and then 2 images of part B. These images will be set up corresponding to the side number and part letter the human assigns.
Also, we have access to buttons, but none are connected yet since I do not know how to connect an external button to the PLC and have it connected to the RS logix 5000 – so if someone could help with that too.
I do have images of what my code currently looks like that I can post for reference. I have also attached the controller tags list, so there can be more universal tag calling.
The steps:
1. Reset the program number on the PLC so the image starts at Prog_000
2. Push an external button to pull the trigger – which takes the image
3. Check the data on the IV2 navigator software through the PLC. If the image is GEQ 80, then continue. If the image is LES 80, then the trigger needs to be pulled again.
4. When the image is good, the program number (prog_000) should increase by one, to Prog_001
5. When the image is not good, the trigger should be pulled again. If the image fails 5 times, the sensor needs to stop. I would think there should be a time delay as well between the trigger being pulled (so the human has time to move the part before the image is taken).
6. This process should continue until it hits Prog_015, so once the program number is GEQ 15, the program number should reset to prog_000.
Disclaimer, I do not know much about PLC’s, and am completely stuck on how to proceed, so any help is appreciated! I have an Allen Bradley...
7,349
I got my PanelView Plus 7 working with a Micrologix 1500. How would I connect my laptop to the PanelView to view the ladder logic while operating...
115
Hello, I am trying to replicate a piece of logic on the PLC5 onto an SEL RTAC. I am using ladder on SEL and FBD. I am having issue on the ladder...
228
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
199
Good morning crew! Ok my logic works but I am missing something. When the start button is pushed it should like the red light for 4sec then shut...
422
