Ladder logic for values sorting in ascending order
itsmerahul
Feb 2016
Pune
Can anyone help Using Gx works 2 or Codesys Software
Want to arrange values in ascending order from ex 1...10
to d1...d10 register after executing start button.
note without using function block of sort
That kind of task is just asking for using ST or IL instead LAD
Start with a piece of paper.
What sort algorithm do you wish to implement?
1. Draw a flow diagram
2. Write code to match your flow diagram
3. Test code
4. Code works? Yes= goto 6 Else continue
5. Code matches flow diagram? Yes= GOTO 1 | No= GOTO 2
6. Job done
Nick
thanks for your valuable reply
for ex
actually if i enter d1 ..3
d2..4
d3...1
d4..2
d5..5
d6...3
d7...8
d8...7
d9...6
d10...0...after executing start button all these value should arrange in ascending order from least value in d1 register...to max value in d10 register in ascending order
My guess is that this is a homework question. If someone just gave you the answer then you would not learn anything.
I refer you to my previous reply.
Post your efforts here and people will be able to help if you're struggleing.
Nick
Hello, I have a new downtime reporting system at work that connects to the PLC and monitors downtime. The reporting system works by reading a...
17,526
I got my PanelView Plus 7 working with a Micrologix 1500. How would I connect my laptop to the PanelView to view the ladder logic while operating...
161
Hello, I am trying to replicate a piece of logic on the PLC5 onto an SEL RTAC. I am using ladder on SEL and FBD. I am having issue on the ladder...
244
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
204
Good morning crew! Ok my logic works but I am missing something. When the start button is pushed it should like the red light for 4sec then shut...
426
